TractorLinks.com
Re: 5 hp briggs
George Marsh
11-08-2013 17:45:21
El Toro
After looking at old cams, there is no decompression valve. That leaves carbon and rust. Motor doesn't get used much. Once it got over the spell, motor seems to be better.
If it does it again I may pull carb and spray valve stem. If that doesn't work pull head and check valve clearance Thanks, George
old
11-08-2013 18:05:18
 Re: 5 hp briggs in reply to George Marsh, 11-08-2013 17:45:21
Common carbon problem or if your real unlucky the valve seat is coming loose which I have seen. By the way got the timer yesterday but not had the chance to work out the wiring of it. Also have not found that cam found the head to that engine but so far not the rest of it
George Marsh
11-08-2013 19:49:47
 Re: 5 hp briggs in reply to old, 11-08-2013 18:05:18
You should be able to figure out wiring with the instructions I sent.
If you find engine numbers, I can look it up to see if it's the right cam.
The numbers on timer may not be the same, but the location of termials is all that counts.
old
11-08-2013 20:39:23
 Re: 5 hp briggs in reply to George Marsh, 11-08-2013 19:49:47
I found some numbers on one engine but did not get a chance to write them down due to a guy who has a vette in my shop coming in to work on it today
