Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
5 hp briggs
George Marsh
11-08-2013 09:09:38
205.188.116.141
I had trouble starting my old 5 hp briggs flat head. Took breather off and added a little gas. When it started, for about 15 seconds the intake valve didn't close all the way and it would blow gas out the carb, miss and blow black smoke. I didn't add that much gas to create the problem. I'm wondering, do the old flat heads use the intake valve as a decompression valve?
Is it possible rust or carbon didn't let the intake valve to close?
Or is it possible I have a case of intake valve set recession?
George
[Reply]   [No Email]
ShadetreeRet
11-08-2013 22:32:10
76.3.100.234
 Re: 5 hp briggs in reply to George Marsh, 11-08-2013 09:09:38
I have never seen,nor do I believe you will find a compression release on the intake valve. This would cause blow-back or backfire through the carburetor, which can not only cause problems but is dangerous. If you have ever seen an engine blow fire back through the carburetor, you will know what I mean. The compression release lets the compression escape through the exhaust valve.
[Reply]  [No Email]
George Marsh
11-09-2013 00:55:41
50.121.112.194
 Re: 5 hp briggs in reply to ShadetreeRet, 11-08-2013 22:32:10
ShadetreeRet That's what I thought until I lost the cam on an 18 hp briggs. Decompression release was on the intake, yes intake. My 13 hp honda the decompression release in on the exhaust.
My 5 hp was blowing gas out the carb at least 8 inches, yet no back firing even though the engine was running extremely rich. That means the intake had to be closed when engine was firing on the power stroke while the intake was open during the compression stroke causing blow back through the carb. Sounds to me like there is decompression happening on the intake valve. I'll do some research on the engine. George
[Reply]  [No Email]
ShadetreeRet
11-09-2013 07:14:44
76.3.100.234
 Re: 5 hp briggs in reply to George Marsh, 11-09-2013 00:55:41
George, I stand corrected. I will admit that I am not up to date on the newer engines, but to me it doesn't make sense to put the compression release on the intake. I guess some, just out of engineering school pencil pusher, decided he knew better. Go figure.
[Reply]  [No Email]
notjustair
11-08-2013 17:46:19
174.250.163.229
Old gas caused it to stick. Been there before. It usually starts for me but as soon as you shut it down it sticks.
Take the head off and spray some miracle juice down the valve guide. Work the valve a few times and have at it.
The older flat heads had "Easy Spin Starting". Never thought about it at the time, but it may have been a compression release. Either way, probably old fuel.
[Reply]  [No Email]
George Marsh
11-08-2013 19:47:13
50.121.112.194
 Re: 5 hp briggs in reply to notjustair, 11-08-2013 17:46:19
I do have staybil in gas. It sure acted like it may have a compression release on intake. Once it cleared up it was fine for the half hour I used it.
[Reply]  [No Email]
El Toro
11-08-2013 16:41:30
96.244.7.206
I would pull the head and see if you can tap that valve lightly to see if it will close. It may have some carbon or rust causing the problem. Squirt some engine oil around the stem. If it will close I would rotate the engine several revolutions to make sure it keeps closing. Hal
[Reply]  [No Email]
George Marsh
11-08-2013 17:45:21
50.121.112.194
 Re: 5 hp briggs in reply to El Toro, 11-08-2013 16:41:30
El Toro
After looking at old cams, there is no decompression valve. That leaves carbon and rust. Motor doesn't get used much. Once it got over the spell, motor seems to be better.
If it does it again I may pull carb and spray valve stem. If that doesn't work pull head and check valve clearance Thanks, George
[Reply]  [No Email]
old
11-08-2013 18:05:18
209.86.226.11
 Re: 5 hp briggs in reply to George Marsh, 11-08-2013 17:45:21
Common carbon problem or if your real unlucky the valve seat is coming loose which I have seen. By the way got the timer yesterday but not had the chance to work out the wiring of it. Also have not found that cam found the head to that engine but so far not the rest of it
[Reply]  [No Email]
George Marsh
11-08-2013 19:49:47
50.121.112.194
 Re: 5 hp briggs in reply to old, 11-08-2013 18:05:18
You should be able to figure out wiring with the instructions I sent.
If you find engine numbers, I can look it up to see if it's the right cam.
The numbers on timer may not be the same, but the location of termials is all that counts.
[Reply]  [No Email]
old
11-08-2013 20:39:23
209.86.226.34
 Re: 5 hp briggs in reply to George Marsh, 11-08-2013 19:49:47
I found some numbers on one engine but did not get a chance to write them down due to a guy who has a vette in my shop coming in to work on it today
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
