Anonymous-0
I am looking at purchasing a used 15,000 watt generator originally sold by Northern Hydrolics. It has a Kohler Command 25 HP engine with a Gillette brushless generator. When started the engine starts at full throttle and when you turn off the engine it is at full throttle. It appears to have no throttle adjustment. The owner says when new it was full throttle starts and stops. Is this normal or is there a problem with throttle linkage or some other problem? This unit has low hours (21) and generator output is ok.
Thanks for any and all comments.
Bud
Bud
