Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 18 hp briggs cam repair?
joe csuti
11-01-2013 18:02:06
The acr cam is usually part of the complete cam assembly,get mod/spec# of eng & goto link below,lookup mod/spec# of eng in briggs eng listings,see if acr listed seperate from cam,if not then write down pn for cam,goto ebay & enter briggs cam in search & check if any new/used cams your pn listed,also do a goggle search for briggs + pn of acr(if seperate)or cam pn & do some online shopping for prices,gaskets are avail seperate or complete set,at most you'll probably only need sump gasket & shaft seal if you choose to replace when case split.
To remove cam,turn eng on flywheel side,support eng so it doesn't move around & flywheel cover clear of bench/floor,remove oil sump,rotate crank till crank/cam timing marks line up,loosen rocker arms so valves are not putting pressure on rockers,pushrods & tappets,pull cam out of block.
joe csuti
11-01-2013 18:17:42
 Re: 18 hp briggs cam repair? in reply to joe csuti, 11-01-2013 18:02:06
After re-reading your post,if you get no movement on either valve,the cam gear is probably broken or teeth broken on gear,on many mod briggs eng the cam gear is plastic/nylon.
George Marsh
11-04-2013 18:14:33
 Re: 18 hp briggs cam repair? in reply to joe csuti, 11-01-2013 18:17:42
Joe, the cam gear is OK. The decompression part on cam is not plastic. Found a few pieces of the decompression part. Definately a problem.
Also having a problem findin pn for the sump gasket. Any help is appriciated. There are 12 bolts holding the sump on.
George
