TractorLinks.com
Re: 18 hp briggs cam repair?
JT
11-01-2013 17:36:40
what model 18hp do you have? If it is a single cylinder, then you removed the push rods, removed bottom cover and take cam out? Are you sure it has a bad cam and don't just need valves adjusted? They get out of adjustment pretty easy and when that happens, compression release does not function. Valve clearance is .004.
George Marsh
11-01-2013 17:51:09
 Re: 18 hp briggs cam repair? in reply to JT, 11-01-2013 17:36:40
Yes, I'm 100% sure it has a bad cam. Yes, it's a single cylinder. Nice to know all I'll need is the engine gasket and not the set.
I've adjusted a few briggs engines, even my honda engine. I blue printed this engine so I knew for certain when it was on compression stroke. Absolutely, no movement in either exhaust or intake valve.
As for cam, can a cam from another single cylinder briggs be used, say a 14 hp?
Is there a cheaper source for a new cam?
Can the old cam be repaired?
Many thanks
george
El Toro
11-02-2013 08:50:09
 Re: 18 hp briggs cam repair? in reply to George Marsh, 11-01-2013 17:51:09
Your local lawn mower shop may have a used cam. Ford and Chevy had that problem back in the 1950's. Some were replaced free. Hal
JT
11-01-2013 17:47:22
George, someone seen you coming, lol, if it is a single cylinder Briggs engine, a new cam should be in the 75.00-80.00 range. The one I looked up for a 33 ci engine, sells for 72.99 for the cam and a 5.00 gasket and 4.40 for the lower seal, where I work at, email is open if you need help getting a little more reasonable camshaft
George Marsh
11-01-2013 17:55:26
 Re: 18 hp briggs cam repair? in reply to JT, 11-01-2013 17:47:22
JT,
My local guy said the same thing, $80. He gave me the price for an entire gasket set, $60.
When I get time, I'll take engine apart and take a look see inside.
At this point friend doesn't want to put $150 in a used mower, when there are many on craigslist for $100-$200 range.
However, the rest of the mower has been well taken care of.
George
