Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 18 hp briggs intek cam problem?
joe csuti
11-01-2013 03:05:06
You should be good with the .004" setting,I don't know how you set clearance on rocker,on the intek single cyl eng the valves are set with the piston PAST TDC & 1/4" into it's downward travel AFTER TDC,try setting valve(s) this way & see if that cures problem.if not I would say acr not working or acr cam worn.the valve timing on these eng is very close,if you set valve at TDC the valve tappet may have been sitting on acr cam,this will allow exh valve to close too early when cranking eng & putting full compression load on starter & starter will stall.
Bret4207
11-01-2013 04:27:50
 Re: 18 hp briggs intek cam problem? in reply to joe csuti, 11-01-2013 03:05:06
Also, check all the wiring on the starter. Corrosion will make a good starter seem weak sometimes. Had that problem several times. Pull the starter, clean everything up and try it.
