Geo-TH,In
Helping a friend get his mower running. I think he has a bad cam. I put my 400 cca battery in mower. Starter won't spin motor over. Took spark plug out; motor spinns just fine. I checked exhaust valve. It was set at .006. I set it to .004. When I turn motor over by hand, shouldn't the exhaust valve open for a moment during the compression stroke, exhaust valve becomes the decompression valve? Well it doesn't. So, I decided to put spark plug in only half way allowing some compression to escape past the plug threads.
It spins over and starts just like it should.
I'm thinking it has a bad cam? Anyone have cam problems with the 18 hp single cylinder briggs? Anyone have experience changing the cam? Any ideas on what to try without taking engine apart?
Perhaps I'll drain the oil and see if there is a spring or something there.
I also posted this on tractor talk. No real good ideas from there.
George
George
