TractorLinks.com
Re: JD lx 178 fuel starvation
joe csuti
10-29-2013 18:17:17
Try running with tank cap loose or removed,if that cures problem then vent plugged or cap bad.If it doesn't cure problem if fuel line exits from top of tank,remove tank fitting on top of tank & check for cracks in fitting,pickup tube inside tank loose on fitting,cracks/split in pickup tube or the more likely cause,screen on filter at bottom of pickup tube dirty/plugged.Before checking pickup tube in tank,if fuel line has an inline filter between shutoff valve/tank,try replacing inline filter first,filter may be dirty/plugged or something in line plugging inlet nipple on filter.
Kris Jensen
10-30-2013 20:41:46
 Re: JD lx 178 fuel starvation in reply to joe csuti, 10-29-2013 18:17:17
thanks Joe.
fuel tank has tube in top of tank. It was fine and clean. tank was cleaned fuel line was cleaned. has a shut off valve just before the in line filter. also good . Went over it all again Was the fuel cap vent. created airlock. blowing back in line would vent it for another five minutes or so but fixing cap has it going again. Thanks
