Anonymous-0
I have johndeerz225eztrak mowerbought as is was not running try to start only clike check fire to starter with light 12volts taken starter off taken apart fielde in side came lose bought new put on crank up running cut five yards now what start again just cliks again beach test start witch is new good replaced start relay with new just clikes got 12v from switch to start relay retest volts get 12v to starter in crank mode release to on and there is 6.5 or better volts still goinging to starts in on mode would this be a bad igswitch problem . the mower is 2007 modle product id moz225a018006 engine bs no lable but around a 15 hp model 31p or 8 707 type 0123 ei code 061130z look likes d please reply with any imfo thanks an have bless day
