TractorLinks.com
Re: Unusal short circuit.
Tom Arnold
10-06-2013 09:36:29
Something does not add up.
If the battery is under the seat and the metal seat made contact with the positive post of the battery when you sat in it, then that is when the short circuit would have taken place instantly. There was no need to turn the ignition key in order for that short circuit to take place. The fact that you blew the main fuse also tells me that you have not found the true problem here. Fuses only blow when the current passing through them exceeds the rating of the fuse. In order for that to happen, the short would have to occur somewhere beyond the side of the fuse that feeds the ignition switch.
Think about it.
Either something else is going on here or you have not told this story as it actually happened.
George Marsh
10-06-2013 15:59:39
 Re: Unusal short circuit. in reply to Tom Arnold, 10-06-2013 09:36:29
I know it sounds crazy to blow the only fuse on mower when the metal seat support, on hinges 2 springs in the back, touched the + terminal at the same I tried to start the tractor. But it happened. I've had mower for 15 years and this is the first time it eat a fuse. Used mower for about an hour with no issues. George
