case310350
New User
Have an old onan engine/welder twin cylinder. The problem is one cylinder about 1/2 the time will start popping, you can see some flame in the exhaust when this happens and with your hand over the exhaust you can feel the popping. then will start running fine for a while and then start again. its not the gas, or a manifold leak
the other cylinder runs fine all the time.
So looking for some suggestions. Could it be a valve that is sticking?
