Yesterday's Tractor Co.
Shop Now View Cart
Re: onan twin opposed m23 engine popping then runs fine
joe csuti
10-04-2013 03:49:46
Many things can cause problem you have,some of the more common causes are plug going bad,coil going bad,insulation on plug lead dried out/has hairline cracks & spark shorting to block,sticking/leaking valve,carbon buildup on valve/valve seat,worn valve guides,loose valve seat,head gasket that's starting to leak,worn cyl/rings,sticking,damaged or broken ring,gasket leaking where intake mainfold bolts to block,loose carb/carb mounting gasket leaking,hairline crack in manifold or a problem in fuel system itself.What you have to do is try and isolate problem to ign system,fuel system or an internal mech problem on/in eng,I know this isn't fun,but there are too many things that can cause problem & you may have more than one cause of problem.
