Harbor freight to the rescue
Geo-TH,In
Needed a new tube 12x4-6 for pressure washer. Looked for hours calling, amazon, ebay, no luck.
Went to harbor freight and they had solid tires for wheelborrows that are 13 inch tires. On sale, with 20% coupond $16.25 out the door. No more flat tires.
George
I did the same thing you did on my chipper,I don't know which style bearing in hub/rim on wheel you bought weather bushed or ball bearing,if ball bearing keep an eye on bearing(s)I found out that either due to bad/cheap bearings used in same they don't hold up well to vibration in the long term,while the wheel is cheap enough to replace it can be a real inconvenience when useing equipment when bearing(s)break/pop out of hub/rim when moving equipment.
Joe, the bearing are ball bearings, just like the OEM. I have many new ones in drawer. Pressure washer isn't going to get many miles on it. After tought, Fill old tire with great stuff foam a littlt at a time.
George
