Yesterday's Tractor Co.
Shop Now View Cart
Re: Honda GX390 starter?
10-01-2013 18:11:11
If you ever need to get locktight loose, just heat to about 3-400 degrees, with a propane torch. loosens right up.
George Marsh
10-02-2013 04:43:19
 Re: Honda GX390 starter? in reply to Diydave, 10-01-2013 18:11:11
If I had put lock tight on the nut, I would have known to heat it. Who puts lock tight on a flywheel nut? Never seen it before. Won't be there when I'm done. Do you see a need for it?
10-02-2013 17:47:29
 Re: Honda GX390 starter? in reply to George Marsh, 10-02-2013 04:43:19
Hard to tell whose been there before you! I had a neighbor bring me one of his aerators up, day before yesterday, the flywheel nut had come loose and stripped out the nut, and boogered up the threads on the crank, pretty bad. I used a thread file, to clean it up, then cut a slot down a lock nut I happened to have, and used it, and a pair of vice-grips to chase the threads a little smoother, then put a new lock nut on, and yes, used red medium locktight on it. Sometimes its a necessary evil!
