TractorLinks.com
Re: Briggs 5.5 hp Intek Carb. Problem - Please Help
jimg.allentown
10-01-2013 15:42:29
Your problem is the feed hole for the main jet. When you take the hex piece that holds the bowl to the body, you will see that it contains part of the emulsion tube that feeds the main jet. There will be a very small hole in the side of this piece that feeds the main jet. If this hole is blocked or partially blocked, the main jet will not get any or enough fuel to keep the engine running. Look it over closely with a magnifying glass if necessary. Clean this hole with a fine wire and some carb cleaner spray, and it should solve the problem.
