I have a Titan Industrial pressure washer that hasn"t ran in about 6 years but the fuel was turned off before storing. I dumped old gas out, washed it off, air blowed dry, and put new gas in and she fired right up and ran good for about 3-4 minutes until I started using the pressure gun. Immediately died and would not start back up like it was not getting fuel. I sprayed a little carb cleaner in the intake to confirm it would then sputter then die. Today I decided to remove the carb to see what the prob. was. I noticed that it looked like water came out of the bowl, so I removed and thouroughly cleaned carb. with spray cleaner and copper wire. I also blew back through the fuel line with air to make sure I had good flow. I filled the tank last night with gas that is a week old in my lawnmower can and it looked as if pure gas is running out of the tank. Put everything back on and the engine starts right up 1st pull on choke and will run for about 3 seconds and die on choke. It will not run or start on any other setting. If I keep feeding carburetor cleaner to intake, it will keep running. Still seems like a fuel issue, but I thought I went over everything!!!
Ahh
Ahh
