Yesterday's Tractor Co.
Shop Now View Cart
Re: John Deere L110 Cuts-off When Hot
joe csuti
09-25-2013 17:20:09
Next time problem happens while eng still hot,sit on tractor crank eng & try to start,while doing this have a helper/someone check for spark at plug,if no spark,if eng has a pressure sw on oil filter adapter disconnect sw & crank eng,if still no spark with sw disconnected then ign coil breaking down from heat/going bad & needs replacement.
If you have spark with pressure sw disconnected then problem in lube system,possible causes-plugged/restricted oil filter,worn oil pump,internal wear in eng causeing loss of oil pressure when eng gets hot,bad sw or wrong wt oil in eng.
Kevin Austin
09-26-2013 06:42:01
 Re: John Deere L110 Cuts-off When Hot in reply to joe csuti, 09-25-2013 17:20:09
Thx Joe!
