JD F525 Schematic
molinegb
Would any have a wiring diagram for a JD F525? Have no idiot lights and would like to repair low fuel light.
Not the easiest parts viewer to read but they do have somewhat of a wiring diagram hidden in there.
When you turn on the key before starting, I think all the lights should light up to let you know bulbs are good.
Look for easy stuff first: Loose/broken wires and fuses.
Enter F525, click "sectional index", then "electrical".
JD site
Picture kinda give me idea. I have power to ignition switch but nothing out. Red wire has supply. Suspect switches on ground side.
Could be a faulty ignition switch. Either the ground is there or it isn't. Do not under any circumstances lose the old ignition switch until you have the correct new one. There are about 20 configurations that JD uses for ignition switches. They sometimes need the old one to find the right one.
Might even be corrosion on the connector. I have had to replace single connectors before because they were so corroded. Most of the time, it is a matter or plugging connector in a few times.
Replaced ignition switch. Didn't help. Found 2 fuses blown. Repalced and now have 2 lights. Low fuel not lit. Brake switch sticky. Now have turning over but won't run unless gas poured in breather. May have to clean carb. Thanks
