TractorLinks.com
Re: Gilson with B S engine
MNGB
09-18-2013 11:07:22
Hi Fred, check that the safety switch is working, it is located directly below the battery, you'll need to remove the battery to see it. It consist of a roll pin about 2" long in the clutch shaft with a light spring with a wire to goes to the solenoid, sometimes the spring gets in front of the roll pin and no contact is made, if that the case simply move the spring to behind the roll pin (toward the rear of tractor). If the spring is where it should be make sure it has good contact they also lose contact and won't work concision, grease or oil etc.
GB in MN
This post was edited by MNGB at 11:11:31 09/18/13.
