214 JD lawn tractor
Im looking for the pictures of where the spring for the large idler/tensioner pulley on the trans goes in a 214 JD lawn tractor..it a variable drive unit..4 speed. the spring broke and I cant find its mounting point on the trans.it has a 1/4" rod attached to the idler bracket then to the spring.. the spring attaches to?? thanks.
The primary belt, like this, or the secondary belt?
its similar..#11 has a link and a spring attached to tensioner pulley bracket that its mounted to. the mounting point of the other end of the spring is what I need to know. I jigged in a spring for now but slow speed has no movement until I move the handle a few clicks
Secondary belt...... I assume there's got to be a bracket or hole for the eyebolt to go through, nuts on eyebolt would have to be adjusted for proper tension.
