Yesterday's Tractor Co.
Shop Now View Cart
Re: Ford LGT 100/ Kohler Engine Question
09-12-2013 16:59:10
have you checked to make sure the governor is working?
09-14-2013 21:17:06
 Re: Ford LGT 100/ Kohler Engine Question in reply to hunting, 09-12-2013 16:59:10
I have a Cub cadet 108 with the same K series engine. The linkage on the engine was so shot you could not believe!!!! The throttle shaft into the carb was shot too. $125.oo for the bushing job on the carb. It was an original Carter. The arm out of the side of the engine had an oval hole. The spring ends were almost ground off. All has been replaced, and adjusted as per the books. The parts were in the $60.oo range. Tractor runs so smooth and even now!!
Ron in Nebr
09-13-2013 09:50:12
Yes the governor seems to be working. I did check and when the engine slows down while mowing, the governor does not move, it is still holding the carb at wide open throttle.
I will do a leakdown test and check the mower deck and reset the timing as the people above suggested. Thanks everyone!
