Anonymous-0
the y2k MTD Yard machine Millenium is running. Apparently the battery won't hold a charge. My sil stopped by and I hit the key to show him how just the solenoid clicks and there was nothing. So I robbed the battery from the other mower and the starter worked fine but no start. Poured a little gas in the carb, it fired right up and continues running. Apparently removing the plunger fixed the gas flow issue. However after it sat there running we noticed a little bit of flame where the exhaust pipe enters the muffler and it also red hot. Plugged muffler? Cut it off and run a straight pipe?
