newatrebuilding
New User
I have a 12 HP Briggs and Stratton L-head engine. I broke the connecting rod. I have never worked on one of these before. Replaced the rings and the connecting rod. It ran fine before I broke the rod.
Now I get blow back through the carb when it turns over. I checked the valve timing and it is dead on. did nothing to the valves, except that when I took the camshaft out the lifters fell out and I have no idea which one was which. When I check the valve clearance I don't have any clearance. I am mystified about what could have made it change. Is there anything else that could cause the blow back?
