david bradley walk behind
I have two david bradleys both are manufactured 1950 to 1953. I need carb rebuild kit and clutch plate. I was wondering because parts are so hard to find would it be better to replace the motors and what engines could be used.
Contact the smallenginewarehouse to see if they have a replacement engine. You will need the model and spec numbers from the old engines. I bought a 10hp B&S for my Troy Bilt tiller in 2006
from them. I sold the 6hp Tecumseh engine for $65.00 that came on the tiller. The replacement engine has electric start. Hal
1-800-321-6725
What are your plans for the garden tractor?
If you replace the engines from original the value will drop like a rock, collectors want something that is original. If you are going to use it and don't care what the collector market value is, then do as you please with it.
Google David Bradley parts. There are at least a couple websites out there with resources listed for parts and try Ebay too. There are lots of DBs still working today.
I have a Continental AU8 engine that runs like a clock, Call Me in N. IL if interested at 815 973 6071 Thanks Doug
