John Deere 180 (not a L T)Riding mower
Mower has not cranked since i washed it down with
diluted de greaser 2days ago.Seems as though it is locked out.The ignition switch is not activating
the solenoid.I can jump it across the solenoid and crank it.I took the switch off of my other 180 it does not activate the solenoid .What should i try?
I had a 165 did the same thing. Check the interlock switch and connector just inside the lower shrouding that the clutch/brake pedal is activating and making good connection.
