Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Cub Cadet RZT50 - bad PTO clutch?
joe csuti
08-06-2013 13:16:17
If you have wiring diag for mower & know which wire/color wire on connector for pto sw goes to pto coil,run a jumper wire from battery pos(+)terminal & connect ammeter between jumper & wire that goes to pto in connector for pto sw and measure current draw on coil,after that check with napa to see what contacts of new sw are rated at,many tractor mfg are useing cheap imported sw's with a 3-4A contact rateing,these sw's will not hold up mech/electrically in the long term,try & get an american made sw with a 5-10A contact rateing & same will probably outlast clutch/tractor,over the yrs deere,mtd & other mfg have had problems with imported sw's with contacts rated at/close to current draw of pto coil.
Dukester
08-07-2013 05:20:54
 Re: Cub Cadet RZT50 - bad PTO clutch? in reply to joe csuti, 08-06-2013 13:16:17
Understood, thanks..I wonder if my NAPA will know the rating though..they had a hard enough time just finding the part!
joe csuti
08-08-2013 03:35:27
 Re: Cub Cadet RZT50 - bad PTO clutch? in reply to Dukester, 08-07-2013 05:20:54
Normally the max voltage/current rateing is marked on the sw mounting bushing plate/sw body,however many times especially with xyz brand/imported sw's its not marked & you take your chances with after market or oem sw's.
Dukester
08-08-2013 07:36:26
 Re: Cub Cadet RZT50 - bad PTO clutch? in reply to joe csuti, 08-08-2013 03:35:27
This is a Delta series 6201 switch, says assembled in USA on plastic package. No ratings on switch itself just the Delta name and patent number.
joe csuti
08-09-2013 03:46:24
 Re: Cub Cadet RZT50 - bad PTO clutch? in reply to Dukester, 08-08-2013 07:36:26
Stay with the oem/aftermarket replacement sw.
After doing a goggle search for for delta 6201 switch the 6201 is a series sw used by many mower mfg,the same has several mod# within the 6201 class designated by a three digit number after 6201,which determines the number of terminals on sw,internal switching action of sw & style of knob,in addition the sw is a snap-in design,I assumed sw had a threaded bushing for mounting sw,also looking at several listings in search with the exception of going to delta website none list the voltage/amp rateing of sw.
Unless you have the electrical knowledge/skill to locate a similar style sw & rewire to operate as orig sw,go with the oem/aftermarket sw & replace when/if needed.
