Bought a Husqvarna zero turn
Buckeye Oliver collector
As mentioned in the post below we ended up with a Husqvarna RZ4623 (23 horse Kohler 46 inch deck). Again I want to thank everyone for their input. I've heard some good things about this mower and some horror stories so we'll see how it turns out. I think it came down to service a smuch as anything. We've got a local dealer that seems very knowledgeable in what they've got. I've got a whole two hours on it but love it so far. Cuts down on mowing time considerably.
Excellent. Keep an eye on the rear axle nut issue mentioned below. You might be able to remedy it before any damage is done. I would not mess with it now but if it ever starts to come loose, retighten it with loctite on threads.
I bought a 1995 LazerZ, 60" with a bad crankshaft(CH22s) for $500(way too much). After I bought it, I found other people with same issue with the crankshaft online. I tried locating a used one but none to be found. I shelled out the cash for a new one and spent about $500 rebuilding engine(new rings, connecting rods, lifters, oil pump, gaskets, and crankshaft). This year, I replaced the blades and lever linkages for better control. Previous blades were for a different machine and never fit the shafts correctly. Ever since we started using it, one drive pump was weak/slow. It turned out to be the loose ball joints on the lever linkages and a loose bolt on the hydraulic control for that side.
My nephews fight over who gets to mow the 2+ acres. The 12 year old loves the machine. The engine is a little noisey like a rod knock but everything looked ok internally. I think the previous owner cranked it with the sump off and caused the cam bearing to be oblong. Or, it is the exhaust "tap, tick" like on headers for cars. I told my nephew to drive it til it blows up and I will find a better engine for it.
