TractorLinks.com
Re: Occasional Hard Starting 14hp Kohler on JD 214
JT
08-04-2013 08:36:20
More than likely the engine is starting hard is because it is worn, an air cooled engine should use less than an oz. of oil per hour run time on the average, if you you are using double that, then that is a good reason why you have to force feed it fuel by closing off the air intake, not enought vacumn to pull fuel out of bowl of carb and up the high speed jet and into the engine. Do a leak down test and you can confirm that.
