TractorLinks.com
Re: What is This!? Funny Lookin' Craftsman
joe csuti
08-04-2013 04:14:48
The 131 in mod# indicates mower built by roper,probably late 50's-mid 60's,the eng is a tecumseh,either h50 or h60,if you clean off flywheel cover/gas tank you may find mod#,spec# & possibly a sn stamped in same,if no sn found with mod/spec numbers the eng is probably a rebranded lauson(mid-late 50's)eng,most mod lauson eng only uses a mod/spec#(very early only used a mod#)when tecumseh bought lauson they added a sn,same is a mfg date code,due to way tecumseh setup sn it will only give you yr eng made but not decade mfg yr in.
This mod/style mower was sold to many large store chains under different names.This mower is very similar in design to units built by rupp & also sold to large/small chain stores under different names,I had one built by rupp & sold by grants,color was the same,only difference was mine had a lift arm on left side even with dash/hood assembly,a 3 sp peerless trans and a 7hp briggs eng.
If you do a google search for sears 131.96270 you can come up with some links for this mod mower
MNGB
08-04-2013 09:00:07
 Re: What is This!? Funny Lookin' Craftsman in reply to joe csuti, 08-04-2013 04:14:48
Its a Roper built mower but has to be a 1967 or later as Roper didn't start building mowers until 1966 when they bought out David Bradley and 1967 was about the first wider use of vertical shaft engines.
GB in MN
