J D 180 hard to crank
Choke has no affect when trying to crank engine.
But it will start easily if a small amount of gas is poured into the carburator.
Need some suggestions on what the problem might be.
Frank
Disconnect the gas line at the carburetor and see if there's a full stream of gas from the tank. Is a fuel pump used ? Has gas been left in the tank over the Winter? It may be gummed up along with the carburetor. Hal
