Every few weeks(when sitting for a week or two)the Kohler doesn't get enough gas. Starts under full choke, low throttle, barely runs for a few seconds.
Has happened three times before. I have replaced fuel filter, fuel line and by loosening clamps,gas runs out of line, gas squirts out of fuel pump line to carb.
Then taking off air cleaner and holding the palm of my hand tightly to carb air inlet, effectively really choking it, it will start and eventually run up to speed. Put everything back together and the rig runs normal, producing good power for hours. (I mow with 47" deck, pulling to tow mowers) It uses a cup of oil every 4 hours and doesn't smoke except at low to full throttle.
Any opinions where to look? Other than the new ones at the JD dealer? : )
Leon
Leon
