Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere STX38 Drive Problem
JeffL
07-31-2013 08:20:26
that is the right drawing, i found the filler cap, really dirty and hard to get to so going to need washing before i can open it. wondering if i should try to drain it and refill. the original owner never greased the front steering so i bet he never changed or checked the hydro.
rrobert
07-31-2013 20:56:56
 Re: John Deere STX38 Drive Problem in reply to JeffL, 07-31-2013 08:20:26
Honestly, I would top it off first to see if it improves performance. Get more miles out of it and then change it next year.
If you use the fluid JD sells you, it will be very expensive to change the fluid and then find out the hrydro pistons were worn.
Don't tell my mechanic friends. I have never changed the transmission fluid on my 2003 F150, 140k miles. Have had it since new. Shifts fine. I had to top fluid off once because the dipstick tube rusted and broke off the bracket. Would leak when I turned corners. I welded it back together and has been fine since.
