Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: cub cadet deck vibration
T.R.K.
07-30-2013 09:36:51
Some other things to check:
Anything wedged in a pulley. When you spin them around do the wobble or is the outer edge off center?
The spindle shaft: Those CCs with the spindle shaft that is more or less a bolt through them and no star where the blade mounts tend to wear a groove in them if the blade is too loose and allowed to slip. Then the blade can be mounted off center, one side in the groove, causing an out-of-balance condition.
Also check the spindle shaft for any wobble. Turn the deck upside down and note where one end of the blade is in relation to a point on the deck shell. Then rotate the spindle shaft until the other end of the blade is there, it should line up the same way. If its off up or down and the blade is not bent, its the spindle shaft bent.
