Yesterday's Tractor Co.
Shop Now View Cart
Re: Onan P220 Govenor/ Surgeing
07-25-2013 19:54:54
Not saying it's your problem but I've got two Onans, a p218 &220 and both have had surging problems. All I've ever done to fix them is spray carb. cleaner in the air horn, where the choke plate is. There's about a half dozen holes around the outside and a couple little holes' air bleeds. Then blow it out with air and go, always has worked for me.
07-25-2013 21:12:43
 Re: Onan P220 Govenor/ Surgeing in reply to gab, 07-25-2013 19:54:54
Governor is NOT the problem. As gab told you, carb IS. Check intake manifold, as well.
robert kummer
07-26-2013 17:52:11
 Re: Onan P220 Govenor/ Surgeing in reply to Bob, 07-25-2013 21:12:43
there is a known problem with the plastic
flyball spacer ( breaking ) on many of the onan P engines.
i do offer a kit using the older steel spacer,
or the new style plastic one.( with the longer tab
that fits into the notch on the gear.
thank you. boomer ( the used onan engine parts guy )
