simplycity carb
paul n.h.
have a simplycity 725 having trouble with carb needs throttle plate and carb rebuild kit problem can not find any numbers on carb the only thing on carb is letter S do not know what year it is any information will help thanks Paul
Hi Paul you need to post the engine make, model number type number and serial number as simplicity doesn't a carb.
GB in MN
I have three Briggs engines with this cab and the biggest problem is dry old gas deposits or a warped paper gasket in the carb. That kit is a REAL bargen,GetONE.. The oldest is 1956 and the newest is 1986. All using the same carb. Simple as dirt and work great. In all three of my generators I use HI.TEST gas and Startron treatment. The enzyme busts up the damn ethanol. The engines love Hi-Test cause regular gas can vary too much and you need to tinker with the main jet. The hi gives you a more consistent product and less tinker. You want NO throttle movement when the engine is working with out a load or a stable load like a bunch of big lights or something. Remember every time that throttle moves it is wearing out the shaft in the carb! A little long Jeffcat.
