TractorLinks.com
Tecumseh Parts list
J. Schwiebert
07-16-2013 17:48:05
Is there an on line source for engine parts lists? What about engines that have Lauson on the tag as well. Thanks in advance. J.
LenND
07-17-2013 15:07:53
 Re: Tecumseh Parts list in reply to J. Schwiebert, 07-16-2013 17:48:05
Try Outdoor Distributors.com.
jeffcat
07-16-2013 21:00:08
Adding some two cents here. A whole bunch of parts show up on flea bay and grab them while you can!!! Some of the old engines of years ago worked great and now would not meet the pollution police regulations. SO sad.
I found with the two Tecumseh engines I have is to run them on Hi Test gas. Set the carb main jet for a nice smooth run at speed and you are all set. This really applies to generators. My Gen set and roto tiller both work GREAT with the good stuff. Jeffcat Jeffcat
joe csuti
07-16-2013 18:07:56
Goto link below & look in tecumseh eng listings for assembly drawings/parts list,engines listed by mod/spec numbers.
joe csuti
07-17-2013 03:25:27
 Re: Tecumseh Parts list in reply to joe csuti, 07-16-2013 18:07:56
To add some additional info as to tecumseh/lauson eng mod#,the mod# on many older tecumseh eng is actually the old lauson mod# system,many of the early mod lauson eng only had a mod# on eng,later a spec# was added to same,when tecumseh bought lauson in the late 50's-early 60's they retained the lauson mod# system,the only thing tecumseh did was add a sn to id tag which is basically useless as same is a mfg date code,either thru an oversite by tecumseh or for whatever reason sn will tell you yr eng built but not the decade of same unless you can determine mfg yr of equipment that eng is on.
wd9garymn
07-16-2013 18:05:35
partstree.com
