QT 16 Bolens
I moved my bolens out of the garage the other day and when I went to put it back it wouldn't turn over. The battery is up, the pto is disenguaged, I checked the starter and it works, I changed the solinoid just in case and the ignition switch. It doesn't turn over with the key and when I turn the ignition to the "on" position and jump start the starter there is no spark. It started up and ran just fine when I moved it out of the garage.
My Murray did that. It jumped at solenoid but nothing at the ign switch. Finally run new switch to the solenoid. After new switch and solenoid I got tired of messing with it. I'll check wiring when I have more time.
DON TX
