John Deere L110 Transmission issue
Rich Miller
New User
I have a John Deere L110 riding mower that after 15 Minutes of operation will not go up any grade or hill.
Dealer says buy a new mower the L110's have a transmission problem and it would be more economical to purchase a new mower. New transmission would cost $1000
This might help. I did see a video a long time ago on youtube showing how to rebuild it. You will have to search for it.
If this is the same transmission as yours, it is worth the try to repair.
The other option is a used transmission off of ebay.
Good luck with it.
Hydro transmission repair
Might need to replace the belt, also I think you can slide one of the idler pulleys to adjust belt tension can"t remember for sure.
Your dealer is blowing smoke. Why would you want to buy a new one? I've seen the same video as rrobert; the overhaul cost is pretty reasonable and the job is relatively straightforward.
