Yesterday's Tractor Co.
Shop Now View Cart
Re: 442 Case hydraulic drive issue?
07-11-2013 10:16:18
Bob, you are the type that won't listen to anyone that has forgotten more about Case/Ingersoll than you ever knew. I also owned four different ones plus a 322 John Deere and after taking the mower off and putting the snowblower on it it went down the road to a guy who stopped to look at it and it was on his trailer before the ink was dry on his check. My dealer put the holding valve on the unit that didn't have it on from the factory and never had an issue going down the hills or up. Would still be using them if our dealer didn't go broke selling farm equipment.
07-11-2013 10:30:51
 Re: 442 Case hydraulic drive issue? in reply to JohnDy, 07-11-2013 10:16:18
Hey, John!
I stated my OPINION in a reasonable and non-condescending manner and am in no way trying to impose it on you OR the IP!
It is an OPINION (and an OBSERVATION of how the darned things work) and no more than that, as is YOUR opinion.
If we all liked the same thing, it would be a dull world!
And if the REST of the world fully enjoyed the Case/Colt/Ingersol hydraulic-drive system as much as a couple of you guys, it would be mainstream today, instead of being relegated to the dustbin of history!
Traditional Farmer
07-12-2013 13:45:52
 Re: 442 Case hydraulic drive issue? in reply to Bob, 07-11-2013 10:30:51
Case garden tractors are like Studebakers used to be a very few die hard fans.Like you said to most people they are very user UNfriendly.Actually with better quality parts and better engineering they could have been a pretty good machine.
Tom Arnold
07-11-2013 15:03:56
Bob, Once again, your ignorance of the breed is showing in your latest post above.
If you knew anything about the world of garden tractors, you would know that their days are numbered. Almost every manufacturer has opted out of the garden tractor segment of the market. The sub-CUT and CUT tractors have taken over. Deere only makes one garden tractor series and that is the 700. Cub Cadet does not make a GT any longer. Dixon's tractor isn't a true GT and neither is Sears. Wheelhorse is gone and the only other one that comes to mind is Simplicity.
As for the CCI branded GT's, it was total mismanagement by Ingersoll's owners that put the company into the position it is in today but the advent of the sub-CUT and CUT models also played a big part.
You are entitled to post your opinion about the Case GT's but your opinion is flawed because you never took the time to learn how to operate it correctly or you would not have formed the opinions you did.
That aside, please tell us all how any of your opinions actually helped breimer with his question?
07-11-2013 22:55:49
 Re: 442 Case hydraulic drive issue? in reply to Tom Arnold, 07-11-2013 15:03:56
Tom, Am I IGNORANT for being straightforward and honest telling the IP his (basket) Case will NEVER perform in the fashion of nearly every other true "hydro" garden tractor that has ever been sold???
Those things are what they are, but they do NOT function in the same manner as the other hydro GT's made in the same era.
(Notice I did NOT say they ere "bad", just stated they were "different".)
Can you HONESTLY dispute that?
I am in NO way condemning them or any lucky folks that may own one of them, just stating that if a WORKING machine is needed there MAY (perhaps) better choices.
Tom Arnold
07-12-2013 03:15:00
 Re: 442 Case hydraulic drive issue? in reply to Bob, 07-11-2013 22:55:49
Bob, You are entitled to give your opinion, just like everyone else is. This is a discussion that has no resolution because it is very similar to the Ford vs GM vs Mopar conversations that have taken place since the advent of the automobile.
I agree that there is a slight difference in "feel" between hydraulic and hydrostatic drive tractors. As I pointed out in my initial reply, both systems have their good and bad points. However, unlike you I do not disparage hydrostatic drives other than to point out that they have very limited capabilities when it comes to powering additional hydraulic functions.
Why do you find the need to characterize briemer's 442 as a "(basket) Case" or continue to imply that hydraulic drive is somehow inferior to hydrostatic drive? Perhaps I have it wrong but in my eyes, you have been condemning hydraulic drive from your very first post. I find that odd because I know of a great many people who abandoned their interest in Cub Cadet, Simplicity, Wheel Horse and even...........dare I say it...... John Deere, after discovering Case.
A properly set-up Case GT can hold its own against any competing brand on all aspects of property maintenance. They have been a high-end, quality machine since their advent and remain so today.
You knew at the outset that your words were going to draw fire from Case enthusiasts but so far, you have not explained why a hydrostatic drive tractor will outperform a hydraulic drive tractor. So how about putting away the bluster and get down to some facts. When it comes to ploughing a field, mowing grass, blowing snow or any other task normally performed by a garden tractor, tell us where the hydraulic drive falls short.
Brian Jasper co. Ia
07-15-2013 21:02:49
 Re: 442 Case hydraulic drive issue? in reply to Tom Arnold, 07-12-2013 03:15:00
I like my 446, 220, and 155, but the hydraulic drive falls short when you have to climb a steep hill. After you've run them long enough shifting from high to low gets to be second nature, but the hydro tractors you just pull back on the speed lever a bit.
Tom Arnold
07-16-2013 04:11:39
 Re: 442 Case hydraulic drive issue? in reply to Brian Jasper co. Ia, 07-15-2013 21:02:49
Hi Range is to be used only for rapid travel across normal terrain to get from one place to another. It is not intended to be used while performing work of one kind or another. Case never intended Hi Range to be used while ascending steep grades or descending them either. Knowing HOW to use your tractor properly is the key to greater satisfaction with it.
If your tractors had difficulty climbing grades in Lo Range, then that would suggest certain parts are badly worn. A diagnostic would need to done on the hydraulic system to determine whether the pump was capable of putting out its rated flow and pressure. The oil should be changed out and fresh 20W50 installed to make sure that wasn't part of the problem.
Brian Jasper co. Ia
07-16-2013 14:00:42
 Re: 442 Case hydraulic drive issue? in reply to Tom Arnold, 07-16-2013 04:11:39
Again Tom, you fail to grasp what was said. If you were reading closely you would see that I have shifting ranges down to a proverbial science. Unless you're mowing 4 or 5 inches off in one pass, how productive is it to mow at 3mph? This is where the hydrostat is more efficient. No need to change ranges when you come to a hill. You can easily mow at the limits of engine power or cut quality. I'm not knocking the Case in any way. They have the same hydraulic capacity as many farm tractors did in the 60's and 70's. It just depends on what you want to do and how fast you want to get it done. I like the big wheels and high clearance. It cuts better than my 1450 Cub does too.
Tom Arnold
07-16-2013 15:51:54
 Re: 442 Case hydraulic drive issue? in reply to Brian Jasper co. Ia, 07-16-2013 14:00:42
I grasped perfectly what you said.
The engineers wrote Operator's Manuals that clearly state Lo Range is to be used when performing "work". Mowing grass is "work". However, there are some owners who insist on performing "work" in Hi Range and then blame the design of the tractor when it fails to ascend grades while cutting grass.
When you push any machine beyond its design limits, then who is at fault? Sure, if a tractor is driven by a hydrostatic pump instead of a hydraulic pump, you can ease off on the control lever. Trust me. I get it. However, I wouldn't trade my Case for any of the hydro powered units that are out there today. Most of them will be in the scrap yard within ten years time but my Case will still be motoring along just fine 40 years from now, thanks to its design and rugged components.
07-11-2013 17:32:59
Dang it Tom even though you are right about the garden tractors it does make a person feel a little sad when you think about what has disappeared. During my younger days I always enjoyed going to the State fair and the local fair to look at the new models. Ariens, Bolens,Case/Ingersoll, Ford, Allis Chalmers, Toro, Wheel Horse, Cub Cadet, Power King, Simplicity, John Deere, just to name a few. Sure I missed many. Sad to see so many disappearing. Wish Eastmann would hook up with a zero turn so they could hang around. Sorry for all the "looking back".
