TractorLinks.com
Re: Gravely mower charging issues
joe csuti
06-19-2013 17:34:43
First thing check for a blown fuse,wiring diag for tractor shows two fuses in wiring harness,one feeds power to ign sw from battery,other fuse is on output of regulator to charge battery.Goto link below & download a service manual for your eng,in section 8 of manual it will tell you how to id/troubleshoot charging system,if charging system proves not to be the problem,looking at wiring diag I would suspect you have a bad ign sw or a problem in wiring harness.Also check that connections for pos(+)battery connection are clean/tight at battery & battery terminal on sol,also check that neg(-) battery connection clean/tight at battery & where cable bolts to eng/chassis,also check that neg(-) connection for sol coil is clean/tight where it connects to chassis.
