Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Gravely mower charging issues
El Toro
06-19-2013 07:37:21
Find a wiring diagram for that engine. You may have a rectifier/regulator that's fed AC voltage. Use a volt meter set on AC volts and with the engine at 1/2 throttle or better you should have about 30 volts. If there's no AC volts your stator is defective. If there's AC volts your rectifier/regulator is probably defective. Check your charging voltage across the battery terminals should see 14.0-14.5 volts at 1/2 throttle or better. As been mentioned your solenoid has nothing to do with your low voltage on your battery. Hal
Copyright © 1997-2015 Yesterday's Tractor Co.
