Yesterday's Tractor Co.
Shop Now View Cart
Re: JD 214 Variator spring adjustment
06-17-2013 12:29:29
Have you adjusted the variator by placing your lever in the 5th notch and then loosen the 3/4" bolt behind the pop in plug while cranking or running the engine? Alowing your pedal to return to it"s correct position.
06-17-2013 12:39:42
 Re: JD 214 Variator spring adjustment in reply to Mark-Ia, 06-17-2013 12:29:29
Hello everyone, thanks for your assistance. Mark-Ia, I did adjust the variator as you described. I tightened the spring about 1/2 inch and now it is working fine. Thanks again!
