1973 Wheek Horse 42 mower deck help
Anyone have a close up picture of a 1973 Wheel Horse 42" mower deck side discharge? I need a close up picture on how the belt tensioner (plastic) inserts fastens top of the mower deck for the slide bar with Idler pulley travels on. Mower deck # 5-1010.
Thanks for any help on this subject. Mike
The nylon slides are held to deck useing 5/16" carriage/hex head bolts(heads on underside of deck)and a flat washer/elastic nut on top of block to hold,there are also flat nylon spacers between slide bar/deck & held by mounting bolts for slides,the slide bar,slide blocks & spacers MUST be kept free of rust/dirt & dead grass for slide bar to operate correctly,depending on amount of wear on spacer/nylon slides tension on slide bar for smooth operation can be set by loosening/tighting nuts for slide mounting bolts.goto link below & search deck mod# in toro listings,enlarge assembly drawing as needed to view mounting on deck.
toro
