Troy Bilt tine holder assembly
Tom/Idaho
I need to replace the seals on the tine holder and am unable to remove the holder assemblies from the tine shaft. The manual I have says to remove the two bolts and then remove the holders. This tiller (TH 1002) does not have the two bolts. It does have a nut and washer on the outside that one would think after removing the holders would come off to replace what ever seal is leaking. I replaced the axel seals without a problem and could use some help on the tine holder removal.
Thanks, Tom/Idaho
If the holders are similar to the one's with bolts
you should be able to hit the holders with a hammer to remove them. I did that on my Troy Bilt when I replaced the same seals. Hal
