Hay hay hay
Update on what I have done and what I have found.
Jumped to the tab on the solenoid and it engages the solenoid and spins the engine. So it is not the starter or solenoid.
Checked the ignition switch with a multitester.
Have power to the switch 12v and when turned, have 12 v throught the switch in all positions.
Have power to both sides of 2 bottom fuses and the top fuse has power when the ign. switch is turned on and when the start position is triggered on the switch.
Can't see inside the relays, so where else in the circuit can the current be stopped? Seat safety swith is disconnected and it ran this way last summer. Don't see any loose or broken wires. The blue wire carries the current to the solenoid tab...where does it originate in the junction block? Or where could it be open?
This problem occurred while it was sitting over the winter.
Help please. Electrical intrigue and mystery are is my favorite pastime.
