Motor mounts on JD 314
Bob ward
New User
I am working on a JD 314. The muffler is too low and interferes with the hole in the cowl so much that it has worn half way through the muffler pipe itself. The motor mounts look OK and the muffler seems Ok but it just does not fit correctly.
Can someone measure the correct height of the front and back motor mounts to see if they have been swapped out incorrectly.
Of course JD wants about $120 for a new set.
Front: AM35264
A - Inside Diameter 0.391 IN
B - Outside Diameter 2.000 IN
C - Length 1.810 IN
D - Hole Size 0.196 IN
E - Flange Thickness 0.062 IN
F - Length 1.400 IN
G - Hole Spacing 2.475 IN
Rear: M46201
A - Inside Diameter 0.390 IN
C - Length 1.000 IN
E - Flange Thickness 0.00 IN
F - Length 0.530 IN
Match up the respective mounts to Type A or Type B in the diagram and add the dimensions, and you can figure out if you have the correct ones in the correct place.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/Deere/DEEREmounts_zps70630831.jpg">
