TractorLinks.com
Re: Case 224
Austin Speigle
06-09-2013 10:41:37
ok i will try to wiggle the blades side ways. Thank you for replying to my question.
Some times when i turn the case off it backfires do you know what would cause this problem.
Determined
06-09-2013 12:08:28
 Re: Case 224 in reply to Austin Speigle, 06-09-2013 10:41:37
Think of it as Kohler's built in early warning system letting you know that this will be the last season for your engine.
You can do a compression test to confirm but it sounds like it is time for a rebuild.
Dave
Tom Arnold
06-09-2013 13:10:48
 Re: Case 224 in reply to Determined, 06-09-2013 12:08:28
Nonsense. There can be several reasons for the backfire problem.
Excess carbon buildup in the combustion chamber can cause a hot spot that will ignite the fuel mixture after the ignition coil is shut off. A hot spot inside the muffler can also cause the unburned mixture to fire.
Next time you use the tractor, do not shut it off immediately. Instead, bring the engine speed down to an idle and wait for at least a minute or two before turning the key off. This will allow the hot spots to cool down.
I also suggest that you make sure you are running the correct heat range of spark plug with the proper gap. Set the points to 18 thou. Be sure that your air filter is not clogged and that the fuel mixture screw is set so that there is no black smoke in the exhaust stream.
The valve lash should also be checked. Go to Kohler dot com and get the Owner's Manual and Service Manual for the K-series engines. They are free downloads. Your engine has ACR which is Automatic Compression Release. You cannot check the compression on engines with ACR without defeating it first because it holds open a valve to make spinning the engine while starting it much easier.
Focus on bringing everything into spec first before condemning an engine that may well have many years of service left in it.
Austin Speigle
06-09-2013 15:48:59
 Re: Case 224 in reply to Tom Arnold, 06-09-2013 13:10:48
Your right. Its weird because i let it idle fore a while then I shut it off. it just sometimes backfires i don't shut it off right away. Thank you for the info.
Austin Speigle
06-09-2013 12:19:12
Thank for replying Ill get the compression tested. Is it cheap to rebuild the engine.
