184 low boy deck
fredmich
I mow with a 184 and a IH 60" mower deck and have a question about the metal strip on the underside of the deck that surrounds the blade cutting area. I think it helps the clippings exit the RH side of the mower. Mine is missing in areas that leaves a bunch of grass clippings on the LH side of the mowing swath. Are these available to buy or must they be fabricated? The deck is in great condition except for that. Any info. is appreciated. Thanks...Fred
fredmich:
I am sure this is a Haban 60" mower deck built for IH.
The part(s) in question are called "shrouds" and are necessary for a clean cut.
In researching this, it appears these shrouds are NLA.
[b:a016593afd]IH-491857-R11[/b:a016593afd] Shroud, RH
[b:a016593afd]IH-491859-R1[/b:a016593afd] Shroud, LH
You may find these as NOS with an internet search.
These can be custom fabricated also.
Thank you for replying, I was hoping you would see my post as I have followed your posts over the years. I'm sorry that they are no longer available because the mower mows so nice and shrouds are prone to damage and deteriation. I think the mower is a 3160A (plate reads 3100161U010268). Again I thank you..Fred
