TractorLinks.com
Re: Wheel Horse 244-5 won't crank
El Toro
06-08-2013 11:12:22
You need to use a volt meter or test lite to see if there's battery voltage to your solenoid when you twist the key to start or press a starter button. There should be voltage being fed to to your switch you can check that with your volt meter or lite. Check that first, if there's no voltage being fed to your switch you won't have any for starting your engine. Could be a broken or loose wire if there's no voltage. Hal
