need float for carburetor
bdunegan
I have a b&s 5hp horizontal shaft engine that i am needing a float for the carb. the numbers on engine are model #132432,type# 4036-01, code #89101607. the engine itself runs great but the float itself is colapsed and all places i have checked want just aboutwhat engine is worth just for the float. Does anyone out there have a junk engine with a good float they would get rid of?
i know partstree has them, and i have found a few others for around $30, but that is the problem. i hate to pay that much for just a float. that is more than the motor is worth. i was hoping someone on here may have one i could buy a little cheaper. thanks for looking for me and thanks for the info.
I just looked at a picture of that float and I have some. If you can get some approximate measurements from your collappse one I may be able to help. Sam
The measurements for the float are 1 3/4" o.d. 1/2" thick, and inside open is 1". The float is perfectly round with the tab for needle valve and hinge pin brazed on top. both sides of the bottom of mine are colapsed and causes carb to flood. hope this helps!
I sent you an e-mail, just let me know if you got it. and thank you so VERY much for all your trouble. It is nice to know that there are still good people out there willing to help!
